Shinto Japanese Two-Handed Saw Rasp - 260mm
- Double sided blade, coarse and fine
- Open lattice construction, eliminates clogging
- Tempered steel teeth, use on wood, laminates, non-ferrous metals, plastics, gypsum board
Shape up with the two-handled Japanese saw rasp. The 260 x 30mm blade is double sided, coarse one side and fine on the other. The open lattice of the blade eliminates clogging. Tempered steel cutting teeth, use on wood, laminates, non-ferrous metals, plastics, gypsum board etc.
EAN Barcode | 4986744631013 |
Grade | Coarse & Fine |
Rasp Length | 260 mm |
Rasp Type | Saw Rasp |
