Axminster Workshop KJD18-9 NVR Switch 230V 1ph
101762
From £21.38 £17.82
6 Reviews
In Stock - Ready to dispatch
  • Flush mounted NVR switch, max power 12A 230V 1ph
  • Size 75 x 120 x 110mm with twin fixing holes @ 110mm centres
  • Double pole NVR switch, locking Emergency Stop button
  • Can be used with additional safety interlocking switches
  • IP54 rated against dust ingress and splashing water
A flush mounted no-volt-release switch with the added benefit of a prominently positioned lock-on emergency stop button. It is capable of switching up to 12A 230V. It has a no-volt-release feature, but not overload protection. It is suitable for use with additional remote safety switches or interlock switches on doors or access panels. Size is 75 x 120 x 110mm deep with two fixing holes on 110mm centres. Please note, you will need 4 x 5mm crimp on female spade connectors. Rated at IP54 protection against dust ingress and water splashing.
4.00 6
