KEDU KJD20-2 Switch 230V 1ph
950696
From £8.38 £6.98
  5. Half Star
40 Reviews
In Stock - Ready to dispatch
  • Small NVR switch for motors up to 0.75 kW (1hp)
  • Common replacement switch for many woodworking or other machines
  • Simple to connect with clearly marked terminals
  • IP54 rated dust cover and positive action push buttons
  • Replaces older KJD6 type switch
The KJD20 230V switch is commonly used on small woodworking machines. Replaces the older KJD6 type switch. Rated at 10amp, it will be suitable for induction motors up to 1hp. Simply connect using insulated spade terminals, the connections being clearly marked for input and output. It is a no-volt-release type of switch, providing safety in the event of an interruption of power. Requires a rectangular hole approximately 22 x 42mm, spring clips holding the switch securely. Fitted with a dust cover with protection of IP54 and having positive action push buttons.
4.70 40
