Lamello Clamex P-10 Small Connector for Zeta
- Unique fitting to overcome many design problems
- Clamps, locking joint in place and is also detachable
- No glue or screws are required, simple assembly
- Only visible sign of joint is a single 6mm hole
- Special 'T' slot needs to be cut by Lamello Zeta biscuit jointer
- For 13mm panels size 52 x 19 x 9.7mm
- Made from fibreglass reinforced plastic for strength
- Suitable for solid wood, composite boards and other sheet materials
Book your demonstration
Lamello products are renowned for their precision and quality, saving you time and money with outstanding results. Our knowledgeable and friendly team are available to demonstrate the Lamello range in person or via a video call. You can see the tools in use and ask questions before placing your order.
Part of the Lamello Zeta range of connectors, the P-10 is small for connecting 13mm panels. Designed to overcome many design assembly problems, this clamping connector is almost totally invisible with only a single 6mm hole showing on the finished joint. The P-10 is biscuit in shape with a special 'T' profile, one side is fitted with a pivot lever and two alignment studs, this can then be clamped to the other mating piece and locked. The lever is driven using a hexagon key though the 6mm hole. The pocket for the P-10 needs to be cut with a Lamello Zeta machine specially developed for this application, cutting the slot and adding the 'T' to the bottom using a unique vertical mechanical drive. Once cut, the connector simply slides in place, no screws or glue are needed. Made from fibreglass reinforced plastic for strength. Overall length is 52mm x width 19mm, each half has a depth of 9.7mm, it is 7mm in width (9.7mm o/a with 'T'). Requires P-10 drill guide.
