LightCraft Professional LED Headband Magnifier
107724
From £53.28 £44.40
  5. Half Star
40 Reviews
  • 15 possible magnifications between 1.0x and 13.0x
  • Detachable headlight with two light levels
  • Headband with adjustable ratchet for comfortable fit
This versatile headband magnifier is designed to make your life much easier when performing intricate close work requiring precision. It is lightweight and comfortable to wear, leaving your hands free. It comes with five lenses and a drop-down eye loupe, used singly or in pairs the lens combinations give 15 levels of magnification from 1.0x to 13.0x. The magnification is impressive, the combination of lenses gives you maximum versatility with a range of working distances from 35 to 350mm.
The rechargeable headlight illuminates evenly and accurately. It has two brightness levels with a clear white light and is detachable from the headband if desired.
Supplied with: lens storage case, USB charging lead and cleaning cloth.
SPECIFICATION
Magnification Working Distance mm/inch
1.0x 300 to 350mm (12 - 14")
1.5x 240 to 260mm (9.5 - 10")
2.0x 215 to 235mm (8.5 - 9")
2.5x 205 to 225mm (8 - 9")
3.0x 160 to 180mm (6 - 7")
3.5x 135 to 145mm (5 - 6")
4.0x 125 to 135mm (5 - 5.5")
4.5x 110 to 130mm (4 - 5")
5.0x 100 to 120mm (4 - 4.5")
5.5x 80 to 95mm (3 - 4")
6.0x 60 to 85mm (2.5 - 3.5")
8.0x 55 to 70mm (2 - 3")
9.0x 50 to 65mm (2 - 2.5")
9.5x 45 to 60mm (2 - 2.5")
10.0x - 13.0x 35 to 55mm (1.5 - 2")
4.60 40
