Mafell DDF 40 Duo Dowell Jointer with Rail Kit 230V
720784
From £1,329.98 £1,108.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • Fully adjustable fences for accurate positioning
  • Produce edge, corner and mitre joints; drill rows of holes
  • The precision of a stationary machine in a hand held power tool
  • Drills pairs of dowel holes at 32mm centres
In addition to the standard Mafell DDF 40 machine this package includes the 800mm Template Guide and two 5mm carbide dowel drills. The package gives you even more versatility from day one.
Compared to other jointing machines the DDF 40 makes great economic sense, as long term there are significant savings by using standard wooden dowels compared to other more expensive alternatives.
The machine drills pairs of dowel holes at 32mm centres. It features fully adjustable fences for positioning against a reference edge. The DDF 40 can produce edge, corner and mitre joints and be used to drill a row of holes at 32mm centres. For anyone making, building or fitting System 32 cabinetry, this is an invaluable machine. It is an ideal tool for those involved in bespoke cabinets or frequently need to build adaptations. The DDF 40 gives you the precision of a stationary machine in a hand held power tool for use in the workshop or on site.
Supplied in a Mafell T-MAX1 case with a range of accessories including 2x 6mm HW dowel drills, 2x 8mm HW dowel drills, 1x auxiliary rest (ZA), 1x set of additional stops (ZAG), 1x hose connector, 1x position indicator (PAZ), 1x side fence set (SA) 320, 1x stop pin insert for battens (LA), 2x Anti-slip mats, 1x 250ml Glue Bottle with 8mm Nozzle, 350x 6mm wooden dowels and 200x 8mm wooden dowels. Also supplied with this kit is a 800mm template guide and 2 x 5mm dowel drills
Warranty Mafell 3 Year Warranty (Registration Required)
Register on the Mafell website and select NMA Agencies, Brighouse from Dealer options.
In case of a warranty claim please contact NMA Agencies NMA Customer Service Team on - Tel: 01484 400488
For warranty issues outside of the UK, tools must be returned to the UK at the customer's own cost.
Register now
