Makita 9404 Belt Sander
- 100mm wide belt
- Industrial rated sander
- High torque 1,010W motor
- Variable speed control 210-440m/min
- Graphite and rubber pads on underside of the belt
- Flush sanding available on one side
The Makita 9404 has a wide 100mm belt and can be used to sand down surfaces such as table tops. Mainly used working with the grain, it is also very good at working across the grain to flatten before working with the grain to leave a clean, even finish. It is fitted with a high torque 1,010W motor and variable speed control 210-440m/min. Graphite and rubber pads cushion the underside of the belt. The housing allows flush sanding on one side. Supplied with dust bag and abrasive belt.
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
- Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
- The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
Abrasive Belt Size | 100 mm x 610 mm |
Belt Speed | 210 to 440 m/min (var) |
Corded or Cordless | Corded |
Dust Collection | Dust Bag Supplied |
EAN Barcode | 088381032667 |
Model | 9404 |
Motor Power | 1,010 W |
Nett Weight | 4.7 kg |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 96 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 85 dB(A) [3.0 dB] |
Vibration Sanding [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
Voltage | 230 V |
