Mirka Pad Savers 81 x 133mm (Pkt 5)
105565
From £31.48 £26.23
1 Review
  • Minimises wear and tear of sander's backing pad
  • Fits between sanding pad and abrasive disc
  • For Mirka DEOS 353CV Orbital Sander
  • Size 81 x 133mm
  • Pack of 5
Mirka pad saver discs greatly extend the working life of the backing pad on your DEOS 353CV orbital sander.
The pad saver sits between the sander and the abrasive, minimising the wear and degradation of your sander's backing pad, caused by heat build-up when sanding for extended periods. In addition the backing pad adds a slight cushioning effect for better performance when contour sanding. When the pad saver eventually wears, simply peel off, discard and replace with a fresh pad saver. These pad savers are a wise investment especially if your sander is in everyday use.
5.00 1
