Mirka Abranet Abrasive Roll 115mm
- An incredibly efficient long lasting abrasive
- Features hook and loop backed open mesh design, eliminating clogging
- Dust free sanding when used with extraction
- 115mm wide, for 1/2 sheet sanders
- 2.5 metre length rolls
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £29.18 £24.32
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.18 £10.98
Abranet® is a revolutionary abrasive material offering dust free sanding with no clogging. The hook and loop backed open mesh design features thousands of tiny holes which will make sure that when used with suitable extraction the passage of dust will be incredibly efficient. Because Abranet® abrasive keeps the surface that you are sanding dust free, this results in a very uniform scratch pattern leaving an ultra smooth finish. It is incredibly durable and will last twice as long as many conventional abrasives making it very cost effective. These hook and loop backed rolls are suitable for a wide range of materials including the decorating, woodworking and automotive industries.
Abrasive Backing | Mesh and Hook and loop |
Abrasive Roll Width | 115 mm |
Abrasive Type | Abranet |
