ModelCraft 8 Piece Saw Set
- Blades suitable for wood, plastic, foam and modelling materials
- Set includes a No.5 with a secure collet fixing
- All packed in a neat zippered case for protection
Axminster Workshop Self Healing Cutting Mat - A4 (210 x 297mm)From £4.98 £4.15
This 8 piece saw set is perfect for modellers and anyone requiring precision and control when cutting or trimming small parts. The range of blades included are suitable for wood, plastic, foam and similar modelling materials.
The set includes a No.5 with a secure collet fixing for the blades and a comfort grip handle. The blades are as follows: 125mm x 19mm (42tpi), 125mm x 25mm (42tpi), 125mm x 32mm (30tpi), 125mm x 32mm (54tpi), 125mm x 50mm (16tpi), a Sabre blade and a Keyhole blade. All packed in a neat zippered case for protection.
EAN Barcode | 5060252029551 |
