NT Sanding Plate Package
720790
From £29.98 £24.98
30 Reviews
In Stock - Ready to dispatch
  • Embossed steel sheet, form long lasting abrasive surface
  • Strong cast alloy handles, supplied with medium grade plate
  • Rectangular 150 x 50mm and 150 x 24mm, triangular 80 x 30mm
NT Sanding Plate is an abrasive like no other. This offer comprises all three of the NT Sanding Plate tools. Each tool is a strong cast alloy handle with an embossed steel sheet fixed to the base. The sheet is an extremely long lasting abrasive, it cuts effectively in all directions. NT Sanding Plate is perfect for smoothing wood, fibreglass, plastics, sculpting, model building and has many other uses. It resists clogging; if debris accumulates on the surface, a wire brush quickly renews your sanding plate’s effectiveness. The abrasive plate is fixed to a handle with screws making changing to a different grade easy. The tools are: rectangular 150 x 50mm, 150 x 24mm, and an 80 x 30mm triangular tool ideal for detail sanding. All supplied with a medium grade plate.
4.80 30
