Numatic PSP 180-11 Vacuum Cleaner
- High performance ECO energy 'A' rated TwinFlo 620W motor
- Unique caddy top design for storing your small tools, cloths etc
- High efficiency Tritex filtration system
- Simple to use HepaFlo dust bags NVM-1CH available separately
- Tough, no nonsense vacuum cleaner for professional cleaning
- Supplied with 32mm Aluminum Accessory Kit
Axminster Workshop Tapered Step Hose Reducer - 21mm to 38mmFrom £13.28 £11.07
This vacuum is a very clever design based on simplicity. The new 620W motor has the same suction power as before but meets the new ECO Design Regulations with an 'A' rated energy value. The HepaFlo filter bags ensure the highest efficiency suction combined with clean and convenient emptying when full. The unique caddy, on top, provides somewhere for the cable, tools, duster and polish. This cheerful little vacuum cleaner will follow you around and make light work of all your cleaning chores. Powerful enough for industrial use and light enough for the home user. Made in the UK and with a 2 year warranty for peace of mind (except tools).
Supplied with the AH0 32mm Accessory kit which includes a 2.2m FloMax Hose, aluminium extension tubes, double taper hose/tool adapter, various brushes and nozzles. Replacement HepaFlo Filter Bags NVM-1CH available separately in packs of 10 (210628).
Airflow Volume | 1,800 litre/min |
Corded or Cordless | Corded |
EAN Barcode | 5028965610121 |
Max Capacity Dry | 8 litre |
Model | Numatic NSP 180 A2 |
Motor Power | 620 W |
Nett Weight | 5.8 kg |
Overall L x W x H | 340 mm x 340 mm x 340 mm |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Sound Pressure Level LpA [Uncertainty K] | 64 dB(A) [0.5 dB] |
Suction | 22.6 kPa |
Voltage | 230 V |
