Polyvine Exterior Wood Varnish - 1 litre
- Enhances and protects the natural beauty of exterior timber
- High resistance to ultra violet and weathering
- Quick and easy to apply - clean brushes with water
Water based varnishes have found favour for interior use eliminating solvent fumes and providing a tough, glass clear non-yellowing finish. Now you can benefit from these properties for your exterior timber with Polyvine's Exterior Wood Varnish. Formulated with a unique UV protection to resist the sun and elements it defends your exterior timber projects whilst letting the glory of the grain show through. With built-in flexibility for a high resistance to blistering and cracking, it is also designed for fast, easy application and maintenance. Coverage 15 - 20m² per litre.
Application Method | Brush \ Roller |
Available Sizes | 1 litre |
Clean Up | Water |
Coverage | 15 m² to 20 m² per litre |
Drying Time | 1 to 2 hours |
EAN Barcode | 729870003606 |
Usage | Exterior |
