PROXXON Diamond Coated Cutting Disc for LHW & LHW/A Angle Grinder
107277
107277
From £21.88 £18.23
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Diamond coated edge for cutting hard materials
  • Suitable for; glass, porcelain, stone and ceramics
  • Cooling holes minimise heat build-up
  • Fits long neck angle grinders LHW and LHW/A
  • 50mm diameter with 10mm bore
This 50mm diameter disc has a diamond coated edge and a 10mm bore. It is designed for making fine cuts in hard materials such as glass, porcelain, ceramics and stone. The cooling holes help minimise heat build-up. It is suitable for the PROXXON long neck angle grinders LHW and LHW/A.
