PROXXON Drill/Grinder Accessories - PACKAGE DEAL
717496
From £29.98 £24.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • PROXXON 18mm Sanding Discs with Arbor
  • Self adhesive sanding discs
  • Mount on to a rubber faced arbor
  • 5 x 120 grit and 5 x 150 grit discs
  • Arbor, 3mm shaft
  • PROXXON Flap Sanding Wheel
  • For general shaping and smoothing
  • 30mm diameter, 120 grit
  • PROXXON Diamond Cutting Disc
  • Cuts marble, brick, plaster
  • Diamond coated edge
  • 20mm diameter
  • PROXXON Wire Wheel Brushes
  • 22mm diameter wire brushes
  • 5x Steel wire brushes
  • PROXXON 38mm Cutting Discs & Arbor
  • 5 pack of 38mm reinforced aluminium cutting discs
  • Arbor with a 2.35mm diameter shank
  • For cutting metals, wood and plastics
  • PROXXON Spring Steel Cutting Blades
  • Spring steel cutting blades
  • Pack of 3
  • 1 each 16, 19 & 22mm diameter
  • For cutting plastic, wood and non-ferrous metal
  • Show More
Package deal comprises accessory for use with the PROXXON drill/grinder.
18mm diameter self adhesive sanding discs which mount onto a rubber faced arbor. Arbor plus 5 x 120 grit and 5 x 150 grit discs. 3mm shaft diameter.
For general shaping and smoothing work on various materials. 30mm diameters, with a 3mm shaft diameter. 120grit.
For cutting marble, brick, plaster and many other materials in the sanitary and electrical fields. Only 0.6mm kerf, 20mm diameter, with a 2.35mm diameter arbor.
22mm diameter wire brushes mounted on an arbor with 2.35mm shaft diameter. Arbor plus 5 Steel brushes.
Reinforced aluminium 38mm diameter discs for cutting metals, wood and plastics. Available as a pack of 5 discs, including an arbor with a 2.35mm diameter shank.
Cutting blades made of spring steel, only 0.1mm thick. For plastic, wood and non-ferrous metals. Three blades included in the pack, one of each: 16, 19 and 22mm diameter, includes arbor with 2.35mm shank.
