PROXXON EL/A Cordless Soldering Iron - 3.6V (2.0Ah)
109495
From £33.58 £27.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Electronically controlled temperature (470°)
  • Integral rechargeable 3.6V battery
  • 2.0Ah capacity for long run times
  • LED light illuminates the working area
This lightweight, electronically controlled temperature (470°) soldering iron frees you from the constraints of a mains lead. Powered by an integral rechargeable 3.6V battery with an impressive 2.0Ah capacity for a long run time. The EL/A features a short heat-up time and an LED light which illuminates the working area. Supplied with protective cover, solder and charging lead (requires a USB to 3pin plug).
Weight 120g.
