PROXXON FBS 240/E Multi-Tool, 110/P Flexi-Shaft & UHZ Holder - PACKAGE DEAL
717583
From £139.98 £116.65
  5. Half Star
6 Reviews
  • PROXXON FBS 240/E Precision Drill/Grinder Multi-Tool
  • Multiple uses; cuts, sands, polishes and grinds, etc.
  • 0.3-3.2mm keyless chuck
  • Variable speed
  • 2 inset rubber body grips
  • Permanent magnet motor
  • Maximum motor power 100W
  • Supplied in a plastic storage case with 43 cutting, grinding, drilling and sanding accessories
  • PROXXON 110/P Flexi-Shaft
  • 1,000mm flexible shaft
  • Six steel collets - 1mm to 3.2mm
  • PROXXON UHZ Universal Holder
  • Ball & socket plus clamp
  • 34mm bore accepts all MICROMOT machines
  • Ball joint may be swivelled in all directions
  • Show More
Package deal comprises the PROXXON FBS 240/E Precision Drill/Grinder Multi-Tool, PROXXON 110/P Flexi-Shaft and the PROXXON UHZ Universal Holder
This 100W multi-tool has a keyless chuck (0.3-3.2mm) to accept a wide range of accessories, well balanced and with variable speed for maximum control. The tool is well designed and the two inset rubber grips on the body ensure a good purchase, important for fine detail work. The permanent magnet motor is powerful and well balanced and the variable speed control gives a range of 5,000 to 20,000rpm. At the opposite end to the drill chuck is a hanging loop, used when the tool is coupled up to a flexible shaft. This tool has a quality specification, a flexible drive shaft with precision handpiece and 1.0mm, 2.4mm and 3.0mm collets is also available as an optional extra. Supplied in a plastic storage case with 43 cutting, grinding, drilling and sanding accessories.
A truly flexible shaft some 1 metre long. The precision aluminium hand piece features a milled steel shaft and dual ball-bearings. The highly-flexible core ensures no overheating even when working tight radii. Length 1,000mm, maximum speed 25,000rpm.
Fitted with a delicate hand piece complete with six steel collets (1.0 - 1.5 - 2.0 - 2.4 - 3.0 and 3.2mm) for accurate holding of rotary tools and collet nut. Suitable for use with any of the PROXXON range of tools or indeed any type of power source that can grip the 3mm male shaft of the unit.
Socket & clamp like the precision vice FMZ. The ball joint may be swivelled in all directions. 34mm bore accepts all MICROMOT machines.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.5 6
