PROXXON FET Table Saw
210576
From £431.98 £359.98
In Stock
  • Perfectly straight cuts
  • Height-adjustable and tilting saw blade
  • Supplied with 80mm x 36 sawblade
  • Table and drive can be lifted up for easy access
  • Micro-adjustable cut length stop
  • Easily stored away when not in use
  • Milled die-cast aluminium table
  • Special DC motor with Optibelt toothed belts
  • Dust adaptor for connection to a vacuum
  • Push stick and zero tolerance POLYCARBONATE table inset
A saw designed for precise cuts
For cutting a range of materials, a variety of blades are also available
Super-Cut Crosscut Blade
85mm diameter x 0.5 x 10mm bore, 80 teeth. For use on hard wood, soft wood and plastics. View blade
Tungsten Carbide Tipped Blade
(TCT) 80mm diameter x 1.5 x 10mm bore, 36 teeth. For use on hard wood, soft wood, plastics and aluminium. View blade
Diamond Coated Blade
85mm diameter x 0.7 x 10mm bore. For use on glass, stone and tiles.  View blade
A saw designed for precise, straight cuts, with a height adjustable and tilting saw blade, up to 45°. It is made for the fine mechanic, model builder, mould making, toy manufacture, architect, model carpenter and fitter. A variety of optional blades allow it to cut a wide range of materials, such as wood, non-ferrous metals, plastics, Plexiglas, PC cards, foam and many others. All load bearing parts and plane-milled table are made of die-cast aluminium making the FET saw very stable.
The table and drive lift for easy access for cleaning or changing the saw blade. The micro-adjustable, precise cut length stop allows cuts as small as 0.1mm to be made and as deep as 22mm. The saw blade, which can be pivoted by 45°, makes the cutting of double mitres possible when used with the angle stop. The FET is driven by a special DC motor with Optibelt toothed belts connecting it to the main ball bearing supported shaft. Standard equipment supplied with the saw includes a 36 tooth Tungsten Carbide tipped saw blade 80 x 1.6 x 10mm. A push stick and a non-slotted polycarbonate sawing table inset for tight tolerances between saw blade and table when cutting small parts. The FET has a dust adaptor suitable for connection to a vacuum for dust free working.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
3.90 18
