PROXXON HKP/A Cordless Hot Glue Gun
108494
From £35.38 £29.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Stick anytime, anywhere, without annoying trailing cables
  • Fast heating up time, electronically controlled temperature
  • Supplied with integrated stand, USB charging cable & 4 x 7mm glue sticks
Stick anytime, anywhere; no trailing cables to tie you down; this cordless glue gun is as handy as they come. The 2.0Ah battery gives you sufficient operating time to complete even larger projects. The HKP/A takes little time to come up to temperature and is electronically controlled to maintain an exact 170°C. It takes standard 7mm diameter glue sticks (supplied with 4 x 100mm sticks) and has a sensitive feed for greater control. The glue sets within 30 seconds. Use it to bond: metal, wood, plastic (also Plexiglas), glass, ceramics, earthenware, cardboard, leather, foams and textiles. The HKP/A is supplied with an integrated stand and a USB cable for charging. N.B. Requires a charging output of at least 2.1amp.
