PROXXON LGS/A Cordless Long Neck Drill Grinder - (Body Only)
- 75mm extended neck for use in inaccessible areas
- Use in slots and channels and make internal cuts
- Strong die-cast aluminium head
- Full-wave electronic speed control
The Proxxon LGS/A offers you performance comparable to its mains-powered cousin. Built to last the gear head is die-cast aluminium and the main body housing is glass-fibre reinforced POLYAMIDE. The soft grip insert gives comfort and improves control.
The LGS/A features a 75mm long spindle neck, allowing access into narrow spaces, for milling, drilling, grinding and polishing and making internal cuts. The compact design and lightweight (800g) when fitted with a battery, make the LGS/A very easy to handle. The continuously variable speed control 7,000 - 23,000 rpm allows you to work in a wide variety of materials.
It comes with a 6mm ER11 collet for 6mm shank bits (ER11 collets are available in a range of sizes for tooling with different shanks).
Note this is a body only tool supplied with a 36g corundum grinding bit, in a cardboard box without battery or charger.
Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 10.8 V |
Chuck Capacity | 6 mm |
Chuck Type | ER11 collet |
Corded or Cordless | Cordless |
EAN Barcode | 4006274298620 |
Model | LGS/A |
Nett Weight | 800g (with battery fitted) |
Rating | Home/Light Trade |
RPM | 7,000 - 23,000 rpm |
