PROXXON MF 70 Milling Machine
371104
371104
- Variable speed motor 5,000-20,000rpm 100W
- Cast iron base
- Work clamping kit supplied
- Wheel graduations 0.05mm, with adjustable zero
- Fully adjustable dovetailed slides
Show more
Show less
This is a super little machine, well suited to modelling work and for the manufacture of small precision components in a variety of materials. The extruded aluminium compound table has low backlash leadscrews and adjustable gib plates for smooth, accurate movement. Supplied complete with a set of six collets of 1.0mm, 1.5mm, 2.0mm, 2.4mm, 3.0mm, 3.2mm diameter and a work clamping kit. An optional set of solid carbide cutters is available, sizes 1.0mm, 2.0mm and 3.0mm.
Base Size | 130 mm x 225 mm |
Collets Supplied | 1.0, 1.5, 2.0, 2.4, 3.0 and 3.2 mm |
Corded or Cordless | Corded |
EAN Barcode | 4006274271104 |
Lateral Table Movement | 46 mm |
Longitudinal Table Movement | 134 mm |
Model | MF70 |
Motor Power | 100 W |
Nett Weight | 7 kg |
Nose of Spindle to Table [Max] | 135 mm |
Overall L x W x H | 270 mm x 270 mm x 340 mm |
Rating | Home/Light Trade |
Spindle Speed | 5,000 - 20,000 rpm |
Spindle Travel | 80 mm |
T Slot Size | 12 mm |
Table Size | 200 mm x 70 mm |
Voltage | 230 V |
