PROXXON MICROMOT 60 Mill/Drill Unit 12V
- Soft grip nose-piece for comfort
- Slim, easily handled and lightweight (230g)
- Smooth running, balanced, quiet motor
- High quality steel collets ensure accurate clamping
- Supplied with 6 collets: 1, 1.5, 2, 2.4, 3 and 3.2mm
- High speed: 20,000 rpm
- For use with MICROMOT 12V mains adaptor
With a diameter of only 35mm and its low weight, the 12V PROXXON MICROMOT 60 has great balance and is easy to manipulate. The soft grip makes for convenient, safe handling and a tool that is a joy to use. The balanced motor with ground spindle and collar bearing make this a very smooth running machine.
This versatile workhorse lets you engrave, cut, sand, polish, grind and more. Whether you are a model builder, detail carver, tool and die maker, jeweller, artist etc, you will find the MICROMOT 60 invaluable. The wide range of PROXXON bits available let you work on steel, wood, non-ferrous and precious metals, glass, ceramics, plastics and stone.
It comes with a set of 5 high-quality MICROMOT steel collets (1 each of 1, 1.5, 2, 2.4, ,3 and 3.2mm). These hardened steel collets have 3 slits. The design results in an increased bearing surface, ensuring positive and accurate clamping of even the smallest shanked bits.
The tool has a standard 20mm collar for stationary use with PROXXON drill stands MB140/S and MB 200 as well as in the universal holder UHZ. The MICROMOT 60 is a single speed machine running at 20,000 rpm. The machine requires a suitable mains adaptor, we recommend MICROMOT mains adaptors NG 2/S, NG 2/E or NG 5/E.
