PROXXON TSG 250/E Disc Sander
474235
From £280.98 £234.15
In Stock
  • Electronic speed control 250 - 750 m/min
  • Includes chart for recommended speeds on different materials
  • Main body of ribbed die-cast aluminium
  • Aluminium extrusion table with a precise T slot
  • Table tilts 15° inwards & 45° outwards
  • Disc diameter 250mm.
  • Dust collection adaptor included
  • Supplied with mitre fence and 2 each sanding discs of 100 grit and 240 grit
A fine, accurate disc sander with variable electronic speed control from 250 to 750rpm. Sands long edges, end sections, radii, mitres and by turning workpiece over - accurate flat surfaces at right angles. Used on soft and hard woods, non-ferrous metals, steel, plastics (Plexiglass and fibreglass), cork and rubber. Includes chart for recommended speeds on different materials. Main body made from ribbed die-cast aluminium. The table is made from an aluminium extrusion profile with an accurate T slot to precisely guide the mitre fence. It also tilts 15° inwards and 45° outwards (a scale facilitates accurate adjustment). The 250mm machined backing disc is driven by a twin ball bearing spindle. Standard, commercially available sanding discs fix firmly and can be replaced quickly. A dust collection adaptor for attaching a vacuum cleaner/dust extractor is included. 230V with drive via toothed belt (reduction ratio 7.3:1). Maximum sanding height 135mm, table 275 x 105mm. Supplied with a mitre fence and two each of sanding discs 100grit and 240grit. Overall size without table 330 x 280 x 230mm.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.00 2
