Z-Saw Blade for Japanese Folding Pruning Saw - 210mm
103685
From £7.48 £6.23
3 Reviews
  • 210mm long replacement blade, high quality Japanese steel
  • 0.9mm thick, 1.18mm kerf with 3.0mm pitch
  • Universal ground teeth for fast cutting action
  • Ni-P plated for wear and corrosion resistance
This replacement blade secures to the handle by a simple screw. The diamond ground teeth cut on both the pull and push stroke, producing fast and clean results. The blade has impulse hardened teeth and electro-less Ni-P plating for greater wear resistance and increased corrosion protection. The blade is 210mm long and 0.9mm thick with a 1.18mm kerf and a 3.0mm pitch.
5.00 3
