SPAX T-STAR Wood Screws Stainless Steel Csk Partial Thread
From £13.42 £11.18 was £24.38 £20.32 Save £10.96 £9.13
8 Reviews
  • A2 stainless steel for all exterior projects
  • 4CUT point bores into the wood
  • Reduces splitting and need for pilot holes
  • Patented thread serrations reduce driving torque
  • Drive more screws per charge
  • Self-countersinking MULTIhead for flush finish
  • T-STAR (Torx) recess virtually eliminates cam-out
  • Recess: 3.5mm = T15; 5.0mm = T20
These premium quality Torx drive wood screws in A2 stainless steel are superb screws for high quality work.
The 4CUT point bores into wood, dividing the fibres and minimising the chance of splitting. There is no longer a need to drill a pilot hole in most woods. The deep thread with patented serrations pulls the screw into the wood, significantly reducing the driving torque required (more screws per charge). The patented MULTIhead has self-countersinking and stopping qualities at the same time. Ribs on its underside cut into the wooden surface, so the head sits flush with the surface. The ribs also act as a brake and prevent over-tightening when fixing metal plates.
A2 stainless steel offers rust-free fixing for any exterior project or in other areas of potential corrosion, such as bathrooms and kitchens.
Partially threaded screws are particularly suitable for fixing wooden boards to wooden beams for example. As the thread tightens securely into the lower piece of wood, the upper piece of wood is forced tightly against the lower piece by the screw head.
A Torx head has two major advantages. Hardly any pressure is required to keep the screwdriver tip in the head recess, virtually eliminating the chances of cam-out. The transmission of the driving force is radial rather than axial, so less effort is needed (even more screw per charge).
4.80 8
