Titebond Original, Ultimate & Glue Pump - Package
- 1 US gallon Titebond Original Wood Glue
- Ideal for all interior furniture projects
- Aliphatic resin suitable for wood, leather, cloth
- Strong initial tack, open time 5 minutes
- Assembly time 10-15 minutes
- 1 US gallon Titebond III Ultimate Wood Glue
- Wood glue for interior and exterior projects
- Initial tack time 30 mins
- Passes ANSI/HPVA Type I water-resistance
- Waterproof formula that cleans up with water
- Titebond Wood Glue Pump
- Pump fits Titebond 1 US gallon containers
- Easy dispensing when refilling smaller bottles
- Eliminates mess and waste
- Show More
Package deal comprises 1 US gallon of Titebond Original Wood Glue, 1 US gallon of Titebond III Ultimate Wood Glue and a Titebond Wood Glue Pump.
Titebond Original is the glue we recommend for use in most interior woodwork projects It provides a strong initial tack and the setting time helps minimise clamping time. This aliphatic resin is popular with joiners, carpenters and cabinetmakers alike. Excess glue is easy to clean off with just a damp rag. Titebond Original is tried, tested and trusted, use it once and you will always stick with it.
Described as an APP (Advanced Proprietary Polymer), Titebond III has been formulated as a dedicated wood glue to give you the ease of application of aliphatic/PVAs and the water resistance of polyurethane glues. Titebond III forms an exceptionally strong bond on wood-to-wood joints; it has longer open time and higher viscosity than conventional PVAs and will maintain integrity at lower application temperatures. It cleans up with water while wet, sands off without softening when fully cured, is unaffected by finishes, solvent and heat and is mildew resistant. It is suitable for interior and exterior use.
Decanting wood glue from large containers into smaller handy dispensers can be messy and wasteful. Thanks to the Titebond Wood Glue Pump, refilling small glue bottles is a clean and simple operation. This pump allows you to dispense glue from the 3.8 litre (1 US gallon) jug into smaller containers. It eliminates spillage and waste.
With dispensing finished, a push-fit stopper covers the spout, preventing the glue from drying out and keeping the pump primed and ready for use. Should the need arise the pump is easy to disassemble and clean with water.
With this durable and convenient pump, wasteful sticky messes are a thing of the past.
