Titebond Quick & Thick Multi-Surface Glue
600201
600201
- 2 x Faster and 3 x Thicker than traditional PVA glues
- Dries clear and is paintable, unaffected by finishes
- Perfect for the workshop and home and craft projects
- Designed for interior projects
- Initial tack time 10-15 mins
- Setting time 24 hours approximately
Axminster Workshop Multi-Purpose Spreading Spatulas (Pkt 6)From £5.38 £4.48
Show more
Show less
Titebond Quick and Thick is the thickest and fastest drying waterbased glue available. You can use it with porous or semi-porous materials and is ideal for wood, pottery, ceramic, stone, glass, fabrics and leather. It provides a strong initial tack with a fast setting speed. However, it does still give you enough time to realign your workpieces. Once set it gives you a bond that is stronger than the wood itself, it is unaffected by finishes and dries clear.
Adhesive Type | Thixotropic PVA |
EAN Barcode | 0037083024036 |
Setting Time | 30 mins/24 hours |
Suitable For | Wood, MDF, Leather, Cloth |
Usage | Interior |
