Tormek DC-200 Diamond Wheel Coarse - 200mm
107991
From ÂŁ211.98 ÂŁ176.65
3 Reviews
  • Exceptional durability; never needs re-truing
  • Sharpens on the flat side as well as the periphery
  • Coarse 360 grit quickly restores dull edges and removes nicks
Initially this represents a significant investment. However, a Tormek diamond wheel offers a multitude of long term benefits.
It is exceptionally durable, it is a one time purchase, diamond doesn’t wear out. The wheel is 200mm in diameter, that will never change. It won’t hollow, dish or groove, it will never require dressing. Diamond is the ultimate abrasive material for sharpening. You can sharpen steels, ceramic and carbide. It will always perform efficiently. It offers rapid steel removal, requiring little pressure and quickly repairs a dull or damaged edge. The diamond surface provides a consistent, high quality finish to your edge tools.
The greatest advantage it gives you is the opportunity to sharpen on its flat side as well as the periphery. Used together with an MB-100 multi base you can sharpen on the side of the diamond wheel to produce a completely flat bevel. The wheel comes with 150ml of ACC-150 Anti-Corrosion Concentrate.
The Coarse diamond wheel (360 grit) quickly removes nicks or dings from an edge or restores a badly dulled tool.
These wheels fit Tormek T-4 models Original and Bushcraft, as well as earlier models with the same wheel dimensions (Tormek T-4, T-3 and 1200).
5.00 3
