Trend Digital Depth Gauge
504063
504063
From £33.88 £28.23
  4. Half Star
15 Reviews
In Stock - Ready to dispatch
  • For setting router cutter depths, fence positions and saw blade heights
  • Internal width of 60mm, adjustable height range up to 80mm
  • Accuracy to within 0.1mm, resolution of 0.05mm (0.002")
  • LCD read-out displays in mm, inches or fractions
  • Removable pin for measuring hole depths up to 50.8 (2")
  • Relative co-ordinate and absolute function
  • Magnets in the feet keep it in place on cast iron tables
  • Auto shut-off after 5 minutes
This digital depth gauge makes setting router cutter depths, fence positions and saw blade heights more accurate than ever before. With a measuring speed of 1.5m/s, it’s also faster. The LCD read-out displays in mm, inches or fractions, with a resolution of 0.05mm (0.002"). The read-out has relative co-ordinate and absolute function. The gauge has an internal width of 60mm with an adjustable height range up to 80mm. You can use it vertically and horizontally. Magnets in the feet keep it in place on cast iron tables. A removable pin allows you to measure holes or mortice depths up to 50.8 (2") deep. Auto shut-off after 5 minutes.
3.40 15
