TSO Products GRS-16 PE v2 Parallel Edge Guide Rail Adaptor
109810
From £144.88 £120.73
1 Review
In Stock - Ready to dispatch
  • Achieve dead square cuts with your Festool, Makita, Triton or Milwaukee track saw
  • Drops onto the guide rail for faster attachment
  • Solid aluminium, anodised for durability
  • Fits onto either Festool or Makita guide rails
  • CNC machined ensuring extreme accuracy
  • Connection to track takes a mere 5 seconds
  • Completely self-aligning, no adjustment necessary
  • 2 x 400mm long reference edges
  • Use from front or back edge of workpiece
  • Notch in each edge allows use of guide rail clamp
  • Unparalleled for speed, accuracy and ease of use
  • Taped and drilled ready to attach the Festool MFT hinged bracket
  • Show More
This GRS-16 PE v2 parallel Edge Guide Rail square fits onto either Festool, Makita or Milwaukee guide rails. Made from solid aluminium, CNC machining ensures extreme accuracy and allows you to achieve dead square cuts with your Festool, Makita or the Milwaukee M 18 fuel track saw. By dropping onto the guide rail instead of sliding from either side, you can attach it to your guide rail faster and more simply. Once you've secured it into the T-slot of your guide rail and closed the latch, you are good to go.
The GRS-16PE guide rail square features two reference edges. The advantage of this feature is it allows you to reference using either the front or back edge of the workpiece depending on the situation. For instance, when cutting kitchen worktop, you can use the rear square edge rather than the rolled front edge to guarantee an accurate result. The ability to reference either the front or back edge gives you flexibility as to the direction of your cut. As in most cases, it is better to have your workpiece underneath the guide rail and the waste on the opposite side. The 400mm long reference edges are at precisely 90° to your track. There is a small notch in the front of each reference edge to allow you to use a guide rail clamp for extra security should you so wish. The extra fitting holes are taped and drilled ready to attach the Festool MFT hinged bracket.
5.00 1
