TSO TPG-30 Parallel Guide System Set
- Ensures highly accurate parallel cuts with guide rails
- Unrivalled for convenience, capability and accuracy
- Combines squaring and ripping into a single operation
- Fits onto either GRS-16 edge adaptors or TPG adaptors
- Can be easily disengaged from a guide rail for storage
- Supplied with Calibration Memoryâ„¢ feature FlipStops
TSO Products Parallel Guide System Rails RH & LH TPG50 (Pair)From £149.98 £124.98
The TPG30 Parallel Guide System is an accessory which fits onto either the TSO GRS-16 or the TSO GRS-16 PE, a TPG guide rail connector can also be used. Once set up the system offers the most capability of any parallel guide system on the market. The TPG30 System facilitates highly accurate and repeatable cuts. The TPG30 System uses simple one-piece T-tracks with rock-solid bolt-on attachment and a FlipStop v2.0 that only moves when you want it to. Metric and Imperial dual dimensions are laser engraved on every T-track. Exclusive Calibration Memoryâ„¢ feature of FlipStop v2.0 removes the need for recalibration when changing between standard and narrow stock rods. TPG30 Set includes:
2 x 760mm (30") dual-dimensioned T-tracks
2 x TPG FlipStop v2.0
2 x Calibration Rods, for narrow cutting
4 x Comfort Grip Star Knobs
1 x 3mm Hex Driver for all adjustments
EAN Barcode | 859448007641 |
Model | 61-364 A |
