UJK Parf Guide System Mk II Centrotec Shaft & 3mm Drill
- Spare or replacement UJK Parf MkII drill bit holder
- Universal 1/4" hex shank with CENTROTEC design
- High quality 3mm drill bit
UJK 20mm Cutter & Split Stop Collar For Parf Guide SystemFrom £41.98 £34.98
This drill bit holder and 3mm drill bit is part of the UJK Parf MkII Guide System. It is used in conjunction with the bearing guided 3mm drill Guide and UJK Parf Sticks for the initial laying out of the grid of dog holes. The shank is 1/4" hex universal fitting suitable for all 1/4" hex quick change systems including the Festool CENTROTEC and 3-jaw drill chucks. This bit will help you produce dozens of UJK Parf Guide bench tops.
Drill Bit Diameter | 3.0 mm |
EAN Barcode | 5052511126040 |
