UJK 10mm Phenolic Router Table Insert Plate
502747
502747
- UJK 10mm phenolic router table insert plate
- Threaded lead-in pin
- To fit 230 x 306mm aperture
- Twist lock insert ring supplied with wrench
- Range of central insert rings available
UJK 10mm Aluminium Router Table Insert c/w Universal BaseFrom £177.38 £147.82
Show more
Show less
This phenolic insert plate measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. At 10mm thick, it offers a very substantial mounting for your router and comes supplied with a removable central insert with a 38mm central hole. Various inserts are available, including one that will accept a standard threaded guide bush for template routing. The insert will accommodate most portable routers and should be drilled to individual requirements.
EAN Barcode | 5052511058839 |
