UJK 10mm Aluminium Router Table Insert
105932
105932
- UJK 10mm aluminium router table insert plate
- Threaded lead-in pin
- To fit 230 x 306mm aperture
- Twist lock insert ring supplied with wrench
- Range of central insert rings available
UJK 10mm Aluminium Router Table Insert c/w Universal BaseFrom £177.38 £147.82
Show more
Show less
This 10mm aluminium insert plate for router tables measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. It is supplied with a removable central insert ring with a 38mm diameter hole with a range of other hole sizes available. This includes one that will accept a standard threaded guide bush for template routing. The insert plate will accommodate most portable routers and should be drilled to individual requirements.
EAN Barcode | 5052511116362 |
