UJK Professional Router Table Fence
- Fence to fit UJK router tables
- Adjustable infeed and outfeed fences
- T-slot for accessories at the top and front of the fence
- Graduated scale provided along top of fence
- Transparent dust extraction port with 63mm outlet
UJK Off Set Bars for Router TablesSpecial Price £7.88 £6.57 was £21.38 £17.82 Save £13.50 £11.25
The UJK Professional Fence consists of a single extruded aluminium section supplied with a transparent 63mm dust port for efficient extraction from above the table. Provision is made for the fitting of guards and accessories with a T-slot at both the top and front of the fence. An adjustable transparent guard is included for your safety. Adjustable scales are provided for attachment at either side of the table and the fence is attached to these and locks into place at the required position. A scale is also provided along the top of the fence with the zero position at the centre. Adjustable infeed and outfeed fences attach to either side of the aluminium section and the central aperture can be opened and closed according to the diameter of the cutter in use. Comes complete with the side channels. Fence measures 904 x 90mm high.
EAN Barcode | 5052511072071 |
