Veritas Lapping Powder 56g(2oz)
AX822760
AX822760
- A range of grits available
- 2oz containers
Show more
Show less
We offer a range of grits, but we recommend 280 grit for twisted, wavy or linished objects, 400 grit for ground surfaces with a slightly rough texture, and 600 grit for surfaces requiring little material removal. While any grit size will ultimately achieve the same end result (since particles become progressively finer during the lapping process), the coarser the abrasive, the longer it takes to achieve a smooth surface. A range of grits available.
