Veritas Miniature Low Angle Block Plane
504079
From £58.18 £48.48
25 Reviews
In Stock - Ready to dispatch
  • Weight only 48g, 60mm long by 19mm wide
  • Fully functional, easy to manoeuvre and control
  • Cast stainless steel body
  • Accurately machined and surface ground
  • Stainless steel Norris-style adjuster
  • A2 tool steel blade (1.5mm thick)
  • Supplied in a French-fitted embossed leatherette box
  • Made in Canada
This version of the Veritas low angle block plane is about a third the size of the original. At just under 60mm long and 19mm wide, it is a useful size for small-scale work or where a larger plane would be difficult to use. The low 12° bed angle combined with the 25° blade bevel gives it a cutting angle of 37°, making it also suitable for end-grain use. The stainless steel Norris-style adjuster lets you set the 12.7mm wide A2 blade with precision. The body is made from investment-cast stainless steel, and has a fixed mouth, machined sides and a ground sole. Weighs 48g. Made in Canada. Supplied in a French-fitted embossed leatherette box.
4.80 25
