Veritas Router Plane
- Ductile cast iron body
- Ideal for cutting dadoes and grooves and inlay or intarsia work
- Spring-loaded collar holds the blade, allowing easy blade adjustment and removal
- Supplied with 12.7mm straight blade and a two-piece 12.7mm spear-point blade
- Includes blade sharpening jig
- A optional side fence is available separately
With a ductile cast iron body accurately machined and ground flat to a high standard, the Veritas Router Plane is ideal for cutting dadoes and grooves or for cleaning out areas to a precise depth. Blade depth is set by a fine screw feed and a positive locking depth stop sets depth of cut. A spring-loaded collar holds the blade, allowing easy blade adjustment and removal. The knobs are positioned for comfort and control. Weight 900g (2 lb), base size 142 x 80mm.
Supplied with two high carbon steel cutters: a two-piece 12.7mm (1/2") straight forged blade, a two-piece 12.7mm (1/2") pointed blade (for final smoothing) and a blade sharpening jig.
The optional fence (available separately) which is made of stainless steel and aluminium can be positioned on either side of the plane and will work on both straight and curved pieces. In addition to using for dadoes or grooves, the router plane is the perfect tool for inlay or for cleaning out areas for hardware installation, where fine control is critical. If you would like to make a pair of custom handles, a hardware kit that includes two turned brass connectors, two hanger bolts, a hex bolt is available.
EAN Barcode | 722356000083 |
Nett Weight | 910 g (2lb) |
Plane Blade Width | 12.7 mm (1/2") |
Plane Sole Length | 80 mm |
