Veritas Saw File Holder
- Helps accurately control the angle of the file as you sharpen
- Rotating collar for setting a positive or negative rake angle up to 30°
- 75mm wide protractor to the fleam angle up to 45° left or right
- Protractor is marked in 5° increments
- Collar with vernier scale marked in 1° increments
- Anodised aluminium body, stainless-steel protractor and brass thumbscrews
- 66mm overall length
- Made in Canada
Vallorbe Precision Swiss Saw File - Double Extra Slim 125mmFrom £12.68 £10.57
This well designed guide helps you accurately control the angle of the file as you sharpen. It has a rotating collar for setting a positive or negative rake angle up to 30°. The 75mm wide protractor helps set the fleam (or bevel) angle up to 45° left or right. The protractor is marked in 5° increments and the collar has a vernier scale marked in 1° increments. An O-ring inside the collar provides light resistance to the vernier scale making precision setting straightforward. It has an anodised aluminium body, stainless-steel protractor and brass thumbscrews. Its overall length measures 66mm. Made in Canada.
EAN Barcode | 722356013137 |
