Veritas Standard Block Planes
717387
From £209.98 £174.98
7 Reviews
In Stock - Ready to dispatch
  • Excellent plane for general purpose work
  • Comfortable to hold with a nice weight and balance
  • Effective cutting angle of 45°
  • Supplied with a PM-V11 tool steel blade
The standard block plane is preferred for general purpose work. The 20° bed angle plus the blade's 25° bevel angle results in an effective cutting angle of 45°. The low profile lever cap fits the hand well, at only 3.2mm higher than its low angle variant (weight 790g(1.3/4lb)). In all other respects, it is the same as the low angle block plane. Included is a lapped blade, 41mm wide and PM-V11 tool steel blade are available. The lapped blades have a flatness tolerance of ±0.005mm or better over the working surface and with an average roughness surface finish of 0.000127mm(5 micro inches) or better.
5.00 7
