Wood Repair Kit - 230V
109139
From £71.38 £59.48
  5. Half Star
6 Reviews
Low Stock - Ready to dispatch
  • Repair cracks, knots, splits, holes and other defects
  • Fast and easy to use, suitable for outdoors and indoors
  • Use Knot Filler on edges and corners
  • Unique wood repair product with many advantages
  • Flexibility, strength and durability in one product
The Wood Repair Kit, consists of the basic elements required to achieve professional and perfect repairs in wood. The Wood Repair Kit comes in a robust storage case containing a Wood Repair BCD-180 Thermelt Application Gun c/w Changeable Nozzle (Pre-Adjusted Temperature - 170º) and a pack of eight 12mm x 150mm Thermelt Filler Sticks (2 each Mahogany, Pine, Oak, and Knot Filler).
The only additional tools required are a small piece of smooth, flat metal to act as a heatsink for fast, effective cooling of the Thermelt Knot Filler and a sharp chisel or single bevel knife blade for slicing away excess Thermelt Knot Filler prior to sanding.
Wood Repair Thermelt Knot Filler is a unique product for repairing all kinds of knots, cracks, splits, defects etc. in wood. It is easy and quick to use, durable, flexible and strong at the same time. Knot Filler is both water-repellent and flexible, which also makes it perfect for outdoor use. It is a non-toxic product, safe for the user and environment.
Get impeccable results with this quick and easy method of repairing cracks, knots, splits, holes and other defects in timber, new or old. Permanent repairs could not be easier:
Apply the Thermelt Knot Filler into the defect using the Knot Filler gun. Cool down the repair with the heatsink for a short while.Then trim flush with a knife or chisel. Sand the repair and apply a finish.
4.30 6
