Festool HSS Drill CENTROTEC Set 6
- Set of HSS bits for wood, plastic, and non ferrous metal drilling
- Conical point for clean precise working
- Suitable for all drills with CENTROTEC fitting, ideal for Festool's CXS and TXS
- CENTROTEC fitting gives fast and easy bit changing
- This set contains 3, 4, 5, 6, 8 and 10mm diameters.
Neatly organise your drill bits and have them always to-hand, with this practical drill bit case. Suitable for all Festool drills, notably with the CXS and TXS 12V and 18V drills. Simply insert it into the CENTROTEC tool chuck and lock it, and you're ready for efficient working.
Included are six high-quality HSS metal drill bits for precise drilling in wood, plastic, alloy and non ferrous metal, with a conical tip for clean drilling, neatly stowed and easily accessible whenever you need them.
The CENTROTEC fitting allows for simple and quick bit change in the Festool CENTRTEC chuck that also locks the bit in place and can be easily ejected even with gloves on for speed and efficiency.
All six are held in the practical lid compartment cassette. You can use the drill bit case either in the lid compartment Systainer or as is.
Set includes: PZ1, PZ2, PZ3, PH1, PH2, PH3, TX10, TX15,TX20,TX25, TX30 and TX40.
