Festool TXS 12 2.5 Set Cordless Drill Driver 12V (2 x 2.5Ah)
- Compact and light-weight design
- Powerful cordless drill driver set for effortless working
- FastFix spindle takes full range of 18V accessories
- 2 x 12V 2.5Ah battery included plus charger
- LED light for work in poorly lit areas
- CENTROTEC system for quick accessory change
- FastFix elbow adaptor gets into very tight areas
- 2 chucks - 10mm FastFix chuck and CENTROTEC tool chuck
- Systainer SYS3 DF M187 case with lid compartment
The smallest product in the Festool 12V range but it packs a strong, cordless punch, and a welcome companion to the Festool 18V family.
Built to the highest quality with a long service life that Festool pride's themselves on, the TXS 12 is no exception, its compact, cordless, strong and precise, your perfect go to tool when you need to get into tight spaces or narrow corners.
Powered by a 12V Li-ion battery (included) combined with the maintenance free brushless E-Tec motor gives you unrivalled performance. Compatible with all chargers in the Festool 18V cordless range (included).
The FastFix interface makes the TXS 12 fully compatible with the full range of Festool FastFix attachments. It comes with the CENTROTEC tool chuck and 10mm FastFix keyless chuck, offering incredibly quick changing between drilling, countersinking and screwdriving bits.
The TXS 12 comes fitted with an LED light for working in dark, cramped corners and, 1/4" hex bits can be inserted directly into the FastFix spindle for screwdriving or drilling in tight spaces. The practical magnetic bit holder on the drill provides handy storage.
Supplied with: FastFix BF-FX 10mm keyless chuck, CENTROTEC WH-CE chuck, AN-XS Angle attachment. 2 x 12V 2.5Ah Li-on batteries, rapid charger TCL 6, belt clip, PZ2 bit, CENTROTEC BH 60CE Imp Magnetic bit holder in a SYS3 DF M187 Systainer case with lid cassette.
