Flexcut MT150 4 Piece Dogleg Chisel Micro Tool Set
107096
From £93.98 £78.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Thursday 15th May
  • Edge is offset from main axis of the tool
  • Undercut and reach into difficult areas
  • Useful tools for cleaning up tight corners
  • For fine detail or undercutting
  • Includes:
  • MT43 1/16" (1.6mm)
  • MT44 1/8" (3.2mm)
  • MT45 3/16" (4.8mm)
  • MT46 1/4" (6.35mm).
  1. Flexcut MT150 4 Piece Dogleg Chisel Micro Tool Set
Total:
£103.96 £86.63
This set features four micro dogleg chisels: MT43 1/16" (1.6mm), MT44 1/8" (3.2mm), MT45 3/16" (4.8mm) and MT46 1/4" (6.35mm).
Dogleg chisels have their edge offset in relation to the main axis of the tool. The design allows you to undercut and reach into areas impossible with access with standard chisels. These micro chisels are particularly useful for cleaning up in the tightest corners or adding fine detail in difficult to reach areas.
They come super sharp, so you can start carving right away. The blades are high carbon spring steel fitted to polished Ash handles, shaped for comfort and control. The steel has impressive edge retention, with the tip hardened to HRC 59-61. All Flexcut gouges and carving chisels are ready to use straight out of the box. Regular stropping will keep them in top condition.
