Flexcut RG Individual Power Carving Chisels
- Fit directly into Proxxon MSG and WeCheer Power Carvers
- Honed and ready straight out of the packet
- High carbon spring steel for edge retention
- Use RG102 handle to use blades when hand carving
- (Handle sold separately)
Individual Flexcut blades with shanks made to fit directly into power carving machines. These blades fit power carvers Proxxon MSG, WeCheer, Foredom, Ryobi, Automach and many similar reciprocating and flexible shaft carvers. Flexcut's RG102 Handle Adaptor (sold separately) allows you to use them for hand carving.
These tools come honed and ready for use. The blades are high carbon spring steel and have a small amount of flexibility, which helps to follow contours when carving. The steel has impressive edge retention, with the tip hardened to Rc 59-61. All Flexcut carving tools are sharpened and polished before leaving the factory to a truly sharp edge. Regular stropping will keep them in top condition.
Model | RG |
