Fuji Q5 Platinum Turbine Unit & G-Xpc Spray Gun
- Package deal comprises the Fuji Q5 Platinum Turbine Unit with the G-Xpc gravity feed spray gun.
- Extra power means less thinning of viscous paints and finer atomisation
- Quietest 5-stage HVLP turbine on the market
Customers Also Bought
The Q5 Platinum Turbine with its powerful 5-stage motor produces approximately 9.5psi. The extra power allows for less thinning of viscous paints and achieves finer atomisation. The Q5 utilises the same patented noise reduction seen in Fuji’s other Q models. The result is the quietest 5-stage HVLP turbine on the market. A key feature is a Master Speed Control to offer you the ability to adjust the psi/cfm to the optimum needed to perfectly atomise your coating and reduce the overspray/bounceback to an absolute minimum.
Supplied with a 30ft Super Duty Hose, manual and ‘5 for 5 Bonus Kit’. The ‘5 for 5 Bonus Kit’ special accessory package comprises a 1,800mm whip hose, wet film gauge, 19 piece spray gun cleaning kit and extra turbine filters. The Super Duty Hose is an ultra durable hose made in North America. It features 27ft of reinforced air hose attached to a 3ft selection of heat hose. Suitable for running through a spray booth wall. It features a plastic collar at the turbine hose connection to make installing and removing the hose hassle free.
Fuji G-Xpc Gravity Spray Gun
The Fuji G-Xpc Gravity Spray Gun features a spray fan control knob to adjust the size of the fan from 3mm up to 300mm and any size in-between. The pattern control knob allows you to adjust to the exact size of the object you are spraying. A 400cc pressurised gravity cup has the Fuji tilt feature, allowing you to spray in any direction including upwards. 100% stainless fluid components, stainless springs, metal knobs and collar, an ergonomic handle that is always cool to the touch. 1.4mm Aircap Set is installed - perfect size for most fine finishing with lacquers, polyurethanes, latex, water based coatings and others.
- Heat Dissipation Box results in much cooler operating temperatures
- Master Speed Control to adjust the psi/cfm to the optimum
- Supplied with '5-for-5 Bonus' kit
- Fuji Spray Guns
- Professional G-Xpc spray gun features spray fan pattern control
- Spray fan pattern from 3mm up to 30mm in diameter
- 100% stainless steel fluid components, no 'O' rings used
- Non-Bleed spray gun for less turbulence of the workshop air
- High-Efficiency 1.4mm air cap installed for even less over spray
- Four other sizes of air caps available, spray all known coatings
