Arbortech HD Abrasive Discs 50mm (Pkt 20)
From £15.28 £12.73
  5. Half Star
7 Reviews
  • For Arbortech Contour Sander, Mini TURBO Plane Kit, Mini Carver
  • Designed for premium performance when power sanding
  • Exceptionally long life, wide range of grits
  • Cloth-backed abrasive unaffected by heat
These 50mm diameters, sanding discs extend the scope of the Arbortech Contour Sander, Arbortech Mini TURBO Plane Kit and the Mini Carver.
They are heavy-duty to withstand harsh conditions when power sanding. The cloth-backed abrasive, unaffected by heat generated during power sanding, has an exceptionally long life.
Supplied in packs of 20 discs of a single grit, ranging from very coarse 40 grit to extra fine 320 grit. Alternatively, there is a mixed pack containing 3 of each grit giving 21 discs in total.
4.70 7
