Arbortech HD Abrasive Discs 50mm (Pkt 20)
AX999801
AX999801
- For Arbortech Contour Sander, Mini TURBO Plane Kit, Mini Carver
- Designed for premium performance when power sanding
- Exceptionally long life, wide range of grits
- Cloth-backed abrasive unaffected by heat
Show more
Show less
These 50mm diameters, sanding discs extend the scope of the Arbortech Contour Sander, Arbortech Mini TURBO Plane Kit and the Mini Carver.
They are heavy-duty to withstand harsh conditions when power sanding. The cloth-backed abrasive, unaffected by heat generated during power sanding, has an exceptionally long life.
Supplied in packs of 20 discs of a single grit, ranging from very coarse 40 grit to extra fine 320 grit. Alternatively, there is a mixed pack containing 3 of each grit giving 21 discs in total.
