From £299.98 £249.98
In Stock
  • 1,000W powerful smooth running motor
  • Extended head reaches otherwise inaccessible spaces
  • Versatile for carving, sculpting and sanding
Customers Also Bought
This versatile tool is packed with innovative features!
The Mini Carver is the ideal tool for small to medium woodworking projects. A robust and compact design allows you to undertake tasks such as rough shaping, wood cutting, sculpting, shaping and more!
Variable speed
Quickly adjust the RPM for optimal cutting and sanding performance.
Vibration reducing handle
Coupled with the quiet motor gives you increased comfort and control when carving for long periods.
Dust collection attachment
Helps to control the wood dust during sanding, minimising clean up and providing cleaner air.
Sanding disc system
Increases the life of the sanding disc and moulds better to timber for exceptional sanding performance.
Optional carving attachments
Mini Industrial Blade
Perfect for freehand power carving; gives you great performance even on tough hardwoods.
Find out more
Mini Pro Blade
Broaden the scope of the Mini Carver; perfect for rough shaping or fine detailing with equal ease.
Find out more
The Mini Carver MkII is fitted with Arbotech’s latest 1,000W motor. Whether shaping, sculpting or sanding it has plenty of power and more. The Arbortech Mini Carver is a hugely versatile power carving tool. From rough shaping to sculpting, texturing, and sanding, the Mini Carver can do it all. The Mini Carver’s narrow, extended neck offers greater access into small areas. This is a perfect tool for medium to small sculptures and carvings as well as adding detail and helping finish larger works. The Arbortech offers power, value, performance, efficiency and versatility.
It uses 50mm diameter blades and sanding discs, The relatively compact size and long neck gives you better control and visibility. Variable speed (6,000 to 18,000 rpm) gives you full control whatever the task: Setting 5 to 6 is for high-performance wood carving and sculpting.​ 3 to 4 for aggressive sanding on rough surfaces. 1 or 2 for smooth, finishing sanding.
When sanding the flexible rubber backing pad allows you to follow the curve, refining the shape and finishing.
The dust extraction outlet when attached to a suitable vacuum is highly efficient. A great bonus when sanding, in keeping airborne dust out of the workshop.
The Arbortech Mini Carver MkII is supplied with a 50mm tungsten carbide Mini Pro Carving Blade, a vibration reducing auxiliary handle, Rubber Backing Pad (Sanding), 15 assorted sanding discs (5 x 80, 180, 320 grit), Dust Extraction outlet, set of spare carbon brushes and a robust Arbortech storage bag.
  • Variable speed for best results
  • Efficient dust collection when connected to vacuum
  • Ideal for medium wood removal and detailed carving
  • Supplied with carry bag, mini industrial blade, 15 sanding discs (5x 80, 180, 320 grit), rubber sanding pad, dust extraction outlet, anti-vibration handle and spare carbon brushes.
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
