Axcaliber Carving & Shaping Cutter
- 100mm diameter blade for carving and shaping
- Very fast stock removal
- Five tungsten carbide blades (6.8mm width with rounded profile)
- Suitable for 115mm angle grinders (22mm bore)
This carving and shaping blade will give excellent results when used on a 115mm angle grinder (22mm bore). Being a little heavier than similar products and well balanced with five tungsten carbide cutting tips, the blade is very smooth in use with a controllable cutting action. The blade is 100mm diameter and the cutting tips are 6.8mm wide with a rounded profile. If you need to remove a lot of material quickly when carving or sculpting this blade will take some beating. N.B. It is important that protective equipment and adequate guarding should be used when using this type of blade.
EAN Barcode | 5052511048212 |
